Command Bar
The Command Bar provides centralized keyboard-driven access to all Zoo Design Studio operations, settings, and navigation commands. Use the Command Bar to quickly invoke modeling operations, adjust preferences, manage projects, and execute workflows without navigating through menus or toolbars.
The Command Bar (also called the Command Palette) is a searchable interface for discovering and executing commands. Access it via:
- Keyboard shortcut: The primary, fastest method
- Menu: View → Show All Commands
- Search: Type command name, description, or related keyword
The Command Bar displays available commands with descriptions, required parameters, and keyboard shortcuts (if assigned). Commands are organized by category and can be filtered by typing.
Opening the Command Bar
Launch the Command Bar using the platform-specific keyboard shortcut or through the menu system. Once open, begin typing to search and filter available commands.
Command Categories
Settings Commands
Settings commands control application preferences, display options, and modeling behavior. All settings commands follow the pattern: Settings · [category] · [setting name]
Available Settings:
- Settings · app · theme: Application appearance (light, dark, system)
- Settings · app · show debug panel: Toggle development/debugging panel visibility
- Settings · app · stream idle mode: Control bandwidth and battery usage during inactivity
- Settings · modeling · default unit: Default length unit for new files (mm, cm, m, in, ft, yd)
- Settings · modeling · backface color: Surface back-face display color
- Settings · modeling · mouse controls: 3D navigation control scheme
- Settings · modeling · enable touch controls: Enable touchscreen gestures for scene navigation
- Settings · modeling · use sketch solve mode: Enable experimental constraint-based sketching
- Settings · modeling · camera projection: Perspective or orthographic projection
- Settings · modeling · camera orbit: Orbit methodology (turntable vs trackball)
- Settings · modeling · gizmo type: Orientation gizmo style
- Settings · modeling · highlight edges: Toggle edge highlighting on 3D geometry
- Settings · modeling · show scale grid: Display reference grid in 3D scene
- Settings · modeling · fixed size grid: Use fixed grid spacing vs. auto-scaling
- Settings · modeling · major grid spacing: Distance between major grid lines
- Settings · modeling · minor grids per major: Number of minor divisions per major grid
- Settings · modeling · snap to grid: Enable cursor snapping for sketch operations
- Settings · modeling · snaps per minor: Snap point density between minor grid lines
- Settings · text editor · text wrapping: Enable/disable text wrapping in code editor
- Settings · text editor · blinking cursor: Control cursor blink behavior
- Settings · projects · default project name: Template name for new projects
- Settings · command bar · include settings: Show settings in Command Bar results
Authentication Commands
Log out: Terminate current session and return to login screen.
Reload app: Force complete application reload (Scene, Features, Code Editor).
Project Management Commands
Open project: Open an existing project by name (displays project list).
Create project: Create new project with specified name.
Delete project: Permanently delete a project (requires confirmation).
Rename project: Change project name (old name → new name).
File Operations Commands
Add file to project: Import local files or Zoo samples into the current project. Available when a project is open.
Supported formats:
- Local:
.stp(STEP),.glb,.fbxb,.kcl - Samples: KCL sample library
Parameters:
- Source: Local Drive, KCL Samples
- Method: Add to current project or create new project
- Sample selection (if using samples)
- File path (if using local drive)
Application Commands
Reset layout: Restore default panel arrangement.
Set layout: Apply predefined workspace configuration.
Create a sample: Create a new project from the Zoo sample library. Available on Home.
Switch Environments: Connect to different backend environment (development, staging, production).
Override Engine: Connect Scene to custom Engine WebSocket URL (development).
Override Zookeeper: Connect to custom Zookeeper WebSocket URL (development).
View Management Commands
Standard Views
Top view: Orient camera to view XY plane from +Z.
Bottom view: Orient camera to view XY plane from -Z.
Front view: Orient camera to view XZ plane from +Y.
Back view: Orient camera to view XZ plane from -Y.
Right view: Orient camera to view YZ plane from +X.
Left view: Orient camera to view YZ plane from -X.
Zoom to fit: Automatically frame all geometry in the viewport.
Named Views
Named View: Create a camera and visibility preset in KCL 3.0 or later. Apply, edit, or remove it from the Views pane.
The legacy commands below are deprecated. Use Named View for new views; the legacy commands
remain available for camera presets stored in project.toml.
Create named view (Legacy): Save the current camera configuration in project.toml.
Load named view (Legacy): Restore a camera preset saved in project.toml.
Delete named view (Legacy): Remove a camera preset from project.toml. Legacy presets are separate from KCL-backed named views.
Navigation Commands
Go to Home: Return to project browser.
Go to Settings: Open settings interface.
Go to Telemetry: View application metrics and diagnostics.
KCL and Code Commands
Set file units: Define default length unit for current file (mm, cm, m, in, ft, yd).
Set experimental features flag: Enable/disable experimental KCL features (warn, allow, none).
Import: Import from project file (STEP, GLB, FBX, KCL) with local variable binding.
Format Code: Apply standard formatting to KCL code editor content.
Create parameter: Define named constant variable for parametric modeling.
Edit parameter: Modify existing parameter value.
Modeling Commands
Sketch Mode
Enter sketch: Begin 2D sketch creation mode.
Line: Draw straight line segments.
Tangential Arc: Draw arc tangent to previous segment.
Rectangle: Draw rectangular profiles.
Solid Creation
Extrude: Project sketch profiles perpendicular to sketch plane. See Extrude for parameters.
Revolve: Rotate sketch profiles around axis. See Revolve for parameters.
Sweep: Carry sketch profiles along path curves. See Sweep for parameters.
Loft: Blend between multiple sketch profiles. See Loft for parameters.
Solid Modification
Fillet: Round edges with constant radius. See Fillet for parameters.
Chamfer: Bevel edges with angled transitions. See Chamfer for parameters.
Shell: Hollow solid bodies with uniform wall thickness. See Shell for parameters.
Hole: Create intelligent parametric hole features. See Hole for parameters.
Boolean Operations
Boolean Subtract: Remove tool body volume from targets. See Subtract for parameters.
Boolean Union: Merge multiple bodies into single solid. See Union for parameters.
Boolean Intersect: Keep only overlapping volumes. See Intersect for parameters.
Boolean Split: Partition bodies into separate sections. See Split documentation for parameters.
Transforms
Translate: Move geometry linearly. See Translate for parameters.
Rotate: Reorient geometry with Euler angles. See Rotate for parameters.
Scale: Resize geometry uniformly or non-uniformly. See Scale for parameters.
Clone: Duplicate geometry with new variable name. See Clone for parameters.
Delete: Remove selected bodies from the model while keeping the features that created them. See Delete for selection and workflow details.
Patterns
Pattern Circular 3D: Distribute geometry around axis. See Circular Pattern for parameters.
Pattern Linear 3D: Repeat geometry along axis. See Linear Pattern for parameters.
Construction Geometry
Offset plane: Create parallel reference plane. See Offset Plane for parameters.
Helix: Generate helical curves for threads and springs. See Helix for parameters.
Surface Operations
Flip Surface: Reverse surface normal direction. See Flip Surface for parameters.
Delete Face: Remove faces to create openings. See Delete Face for parameters.
Blend: Create transitional surfaces between edges.
GD&T Annotations
GDT Flatness: Annotate planar surface flatness tolerance. See Flatness for parameters.
GDT Datum: Define datum reference features. See Datum for parameters.
GDT Angularity: Annotate angled orientation tolerance relative to datum references. See Angularity for parameters.
Appearance and Visualization
Appearance: Set material properties (color, metalness, roughness, opacity). See Appearance for parameters.
Constrain length: Apply length constraint to sketch segments.
Constrain with named value: Reference parameter in constraint definition.
Export and Manufacturing Commands
Capture screenshot: Save the visible modeling viewport as viewport-screenshot.png. See
Capture Screenshot for
details.
Export: Export current model to various formats:
- STEP (
.step,.stp) - STL (
.stl) - OBJ (
.obj) - glTF/GLB (
.gltf,.glb) - PLY (
.ply) - FBX (
.fbx)
Parameters:
- File type selection
- Storage location (local, cloud)
- Up axis (Y-up, Z-up)
- Scale factor (unit conversion if needed)
Make: Send model directly to networked 3D printer (experimental).
Using the Command Bar Efficiently
Search and Filter
Type any part of a command name, description, or parameter to filter results:
"extrude"→ Shows Extrude command"theme"→ Shows Settings · app · theme"project"→ Shows all project-related commands"boolean"→ Shows Boolean Subtract, Union, Intersect, Split
Command Execution Workflow
- Open Command Bar (keyboard shortcut recommended)
- Type search term to filter commands
- Select command from filtered list
- Enter parameters in the modeling dialog or the command's palette prompts.
- Confirm execution with Submit in a modeling dialog, or Enter/Return in palette prompts.
Modeling Dialogs
Modeling commands such as Extrude, Revolve, Fillet, Boolean operations, and transforms open a dialog beside the Scene. The toolbar and Command Bar open the same dialog.
- Click a selection field, then pick the geometry in the Scene, Code Editor, or Feature Tree. Switching selection fields keeps the geometry already chosen for the other fields.
- When creating an operation, use the trash icon beside a selection to remove it.
- Edit parameter fields directly. Leave an optional field blank to use its default behavior.
- Expand Advanced for additional options when the command provides them.
- Click ? beside an argument to open its documentation.
- Drag the dialog by its header if it covers geometry you need to select.
- Use the Bodies pane or Feature Tree to show or hide geometry as needed while the dialog is open.
- Click Submit to apply the operation, or Cancel or Esc to discard the draft.
- If a validation error appears at the bottom, correct the arguments and submit again. Your draft is preserved.
Double-click a supported operation in the Feature Tree to reopen its dialog. Existing geometry selections are read-only during an edit; change those references in KCL when needed, or delete the operation and recreate it.
Commands such as settings, project management, Import, and Export continue to use palette prompts.
Recent Commands
The Command Bar remembers recently-used commands and prioritizes them in search results, enabling rapid repetition of common workflows.
Keyboard Navigation
Navigate the Command Bar entirely from the keyboard:
- ↑ / ↓ arrows: Select command from list
- Enter: Execute selected command or confirm parameter
- Esc: Cancel Command Bar or parameter entry
- Tab: Auto-complete command name (when unique match)
Command Bar vs Menu vs Toolbar
| Access Method | Best For | Advantages |
| Command Bar | Power users, keyboard workflows | Fastest access, searchable, discoverable |
| Menu | Infrequent operations, browsing | Organized by category, visible structure |
| Toolbar | Visual users, common modeling actions | Discoverable, mouse-friendly, always nearby |
For maximum productivity, learn Command Bar keyboard shortcuts for frequently-used operations. This eliminates UI navigation overhead and enables uninterrupted design flow.
