Top Bar
The Top Bar is the always-visible bar at the top of Zoo Design Studio while you are working in a project. It gives you quick access to project navigation, undo and redo controls, the Command Bar, publishing, and account actions.
Left to Right Layout
Project Area
It contains:
- The Zoo logo, which returns to Home
- A project dropdown menu when the menu is enabled
- The current project and file breadcrumb in the dropdown trigger
- The project name as static text when the dropdown is not enabled
The project dropdown can include:
Project settings, with its keyboard shortcutReveal in file explorer, on desktopAdd file to project, with its keyboard shortcutExport current part, with its keyboard shortcutMake current part, on desktopGo to Home, on desktop and in the browserNew Window, on desktop when you want a separate workspace
Export current part and Make current part can show Awaiting engine connection when the
relevant command is not available.
Undo, Redo, and Reload
They contain:
Undo, which reverts the last modeling or editing actionRedo, which reapplies the last undone actionReload, which refreshes the app or current project state for troubleshooting
Command Bar
The Command Bar button opens the Command Bar for fast search and execution of commands.
It shows the command shortcut in the button, such as Cmd+K on macOS or Ctrl+K on Windows and
Linux.
Publish Button
The Publish button opens the Aquarium submission form for the current project. Add a title,
description, and at least one category, then select Submit for review. Zoo Design Studio uploads
eligible files from the entire project folder, including subfolders. Files ignored by .gitignore,
version-control metadata, internal metadata, and the generated thumbnail are excluded.
If the project is in a Directory library on desktop, the dialog also discloses that a successful submission moves the project into Personal Cloud and starts cloud sync. The Aquarium title is currently also used as the project title, so it can rename the project and its desktop working-copy folder.
You must be signed in and have a Zoo username before publishing. The button is disabled when the
current KCL file is empty or contains errors. Existing submissions can be edited and sent again with
Update submission.
See Aquarium for the complete publishing and review workflow.
Project Share Links
Zoo Design Studio does not currently create direct project share links. To share a project publicly, publish it to Aquarium and use its public Aquarium URL after approval. Aquarium publishing is public and does not replace private or organization-restricted sharing.
User Menu
The right side of the Top Bar is the user menu, opened from the user avatar.
It contains:
- The user name and email at the top
Manage Zoo accountUser settings, with its keyboard shortcutKeyboard shortcutsRequest a featureReport a bugAsk the communityRelease notesCheck for updates, on desktopSign outSign out of all environments, on desktop when multiple environments are active
The menu uses dividers between logical groups of actions.
Visual Order
The Top Bar typically appears in this order:
- Project area
- Undo, redo, and reload
- Command Bar
- Publish
- User menu
Platform and Layout Notes
- The exact arrangement changes slightly with screen size and platform
- The Publish button is hidden in smaller layouts
- Desktop-only actions such as
Make current part,New Window, andCheck for updatesare not shown in the web version
What This Page Does Not Cover
This page covers the application bar and session controls, not the full set of modeling
operations. For modeling features such as Extrude, Revolve, Loft, and Sweep, see the
3D Design section.
