Point-and-Click Tutorials
Learn the core Zoo Design Studio workflow through this nine-part video series. Start with the interface and sketching, then continue through solid creation, body modifications, Boolean operations, transforms, construction geometry, and patterns.
The player below contains the complete series. Use its playlist menu or previous and next controls to move between lessons without leaving the docs, or watch the full playlist on YouTube.
Lessons
  1. UI Overview introduces the main areas of the Design Studio workspace.
  2. Sketch Basics shows how to start a sketch and create the profiles used by downstream features.
  3. 2D to 3D: Extrude, Sweep, Loft & Revolve covers the primary solid-creation tools.
  4. 3D Modifications: Shell & Hole demonstrates two ways to modify an existing solid body.
  5. 3D Modifications: Fillet & Chamfer covers edge finishing in Modify Solids.
  6. Boolean Operations: Union, Subtract & Intersect shows how to combine and cut bodies.
  7. Transformations: Translate, Rotate, Scale, Clone & Mirror covers the main transform tools.
  8. Construction Geometry: Offset Plane & Helix introduces construction references.
  9. Patterns: Linear & Circular Pattern demonstrates the pattern tools.
Each lesson is also embedded on the corresponding reference page, where you can find detailed instructions for the tools shown in the video.
