Project Instructions
Use an AGENTS.md file for instructions that should apply whenever Zookeeper works in a particular project. This keeps project conventions with the model instead of repeating them in every prompt.
Project instructions are useful for preferences such as:
  • Default units and dimensional conventions.
  • Naming, comments, and file organization.
  • Manufacturing assumptions or required clearances.
  • Whether reusable geometry should use custom KCL functions.
  • Features or files that Zookeeper should preserve during edits.
One-off design requests still belong in the chat. KCL syntax and general language rules belong in the KCL documentation, where both people and Zookeeper can find the same answer.
Create the file
The filename is case-sensitive and must be exactly AGENTS.md. Put it at the project root so its scope is unambiguous. You can create and edit the file without leaving Zoo Design Studio:
  1. Open the Project Files pane.
  2. Click empty space in the file tree to clear any nested selection, or select a root-level file such as main.kcl. New files are created inside the selected folder or next to the selected file.
  3. Click the file-plus button (New File...) in the pane header.
  4. Enter AGENTS.md and press Enter. Including the .md extension prevents Zoo Design Studio from adding the default .kcl extension.
  5. Select AGENTS.md in the project tree. It opens as Markdown in the Code Editor pane.
  6. Add the project instructions. Changes are saved to the project automatically. Wait at least one second after your last edit, or switch files to flush it immediately, before asking Zookeeper to use the new instructions.
You can also ask Zookeeper to create or update the file, for example:
Create an AGENTS.md for this project. Use millimeters, use lower camel case names, preserve the mounting interface during edits, and use custom functions for parameterized features that repeat at different sizes.
Zookeeper only writes AGENTS.md when you ask it to. It never creates or edits the file on its own initiative, so the conventions you record there stay yours. If a project would benefit from one, Zookeeper suggests it and waits for you to decide.
In the desktop app, Reveal in file explorer lets you edit the same file with an external text editor instead.
Write outcome-focused instructions
State the convention or invariant once and explain the reason when it changes how the model should be structured. Keep instructions specific to the project.
Avoid copying API reference material into AGENTS.md. Link to the relevant KCL documentation or describe the desired outcome instead. This keeps instructions short and prevents project guidance from becoming stale as KCL changes.
Do not put credentials, access tokens, or other secrets in project instructions.
Precedence and scope
Zookeeper treats AGENTS.md as project preferences. System safety and product constraints still take precedence, so conflicting project instructions are ignored.
If a project contains more than one AGENTS.md, Zookeeper uses the file closest to the project root. Prefer a single root file until directory-specific instruction scopes are supported.
The file affects Zookeeper's work in that project. It does not change global Zoo Design Studio settings or automatically apply to other projects.
Documents Zookeeper maintains
AGENTS.md is your input to Zookeeper. Zookeeper also keeps its own working documents in the project, written as Markdown files with descriptive names. It creates and updates them on its own judgment whenever a task benefits from a written record, such as design decisions and the assumptions behind them, open questions, the state of multi-step work, or context worth carrying into later conversations.
These are ordinary project files. They open as Markdown in the Code Editor pane, they sync and diff like any other text file, and you can edit or delete them whenever you want. Editing one is a useful way to correct an assumption Zookeeper recorded, because it reads its own documents before continuing earlier work.
Expect them on longer or multi-part tasks. They supplement the CAD work rather than replacing it, so a request for a model still produces a model. If you would rather keep a project free of them, or want them named or organized a particular way, say so in AGENTS.md.
Custom functions and editability
Custom KCL functions are useful for a parameterized feature that repeats with different inputs. However, point-and-click tools cannot currently edit sketches inside custom function bodies. Keep sketches at the top level when point-and-click editing is more important than reuse. Use AGENTS.md to choose the default that fits the project, and override it in chat for a specific task when needed.
See KCL Functions for function syntax and reuse options.
