kcl-samples → a-parametric-bearing-pillow-block
// A Parametric Bearing Pillow Block
// A bearing pillow block, also known as a plummer block or pillow block bearing, is a pedestal used to provide support for a rotating shaft with the help of compatible bearings and various accessories. Housing a bearing, the pillow block provides a secure and stable foundation that allows the shaft to rotate smoothly within its machinery setup. These components are essential in a wide range of mechanical systems and machinery, playing a key role in reducing friction and supporting radial and axial loads.
// Define constants such as length, width, height, counter-bore depth and diameter, bearing diameter, hole location padding, and more
length = 6
width = 4
height = 1
cbDepth = .25
cbDia = .7
holeDia = .375
padding = 1.5
bearingDia = 3
// (Needs to be updated). Sketch the block and extrude up to where the counterbore diameter starts.
extrude001 = startSketchOn('XY')
  |> startProfileAt([-width / 2, -length / 2], %)
  |> line(endAbsolute = [width / 2, -length / 2])
  |> line(endAbsolute = [width / 2, length / 2])
  |> line(endAbsolute = [-width / 2, length / 2])
  |> extrude(length = height)
extrude002 = startSketchOn(extrude001, 'end')
  |> circle(
      center = [
         -(width / 2 - (padding / 2)),
         -(length / 2 - (padding / 2))
      radius = cbDia / 2,
  |> patternLinear2d(
      instances = 2,
      distance = length - padding,
      axis = [0, 1],
  |> patternLinear2d(
      instances = 2,
      distance = width - padding,
      axis = [1, 0],
  |> extrude(%, length = -cbDepth)
extrude003 = startSketchOn(extrude001, 'start')
  |> circle(
        center = [
        radius = holeDia / 2,
  |> patternLinear2d(
      instances = 2,
      axis = [0, 1],
  |> patternLinear2d(
      instances = 2,
      axis = [1, 0],
  |> extrude(length = -height + cbDepth)
extrude004 = startSketchOn(extrude001, 'end')
  |> circle(
      center = [0, 0],
      radius = bearingDia/2,
  |> extrude(length = -height)
