kcl-samples → 80-20-rail
80-20-rail
// 80/20 Rail
// An 80/20 extruded aluminum linear rail. T-slot profile adjustable by profile height, rail length, and origin position
@settings(defaultLengthUnit = in, kclVersion = 1.0)
// Create a function to make the 80-20 rail
fn rail8020(originStart, railHeight, railLength) {
// Sketch side 1 of profile
sketch001 = startSketchOn(-XZ)
|> startProfile(at = [
originStart[0],
0.1 * railHeight + originStart[1]
|> arc(angleStart = 180, angleEnd = 270, radius = 0.1 * railHeight)
|> arc(angleStart = 180, angleEnd = 0, radius = 0.072 / 4 * railHeight)
|> xLine(length = 0.1 * railHeight)
|> xLine(length = 0.06 * railHeight, tag = $edge1)
|> yLine(length = 0.087 * railHeight, tag = $edge2)
|> xLine(length = -0.183 * railHeight, tag = $edge3)
|> angledLine(angle = 45, endAbsoluteY = (1 - 0.356) / 2 * railHeight + originStart[1], tag = $edge4)
|> xLine(length = 0.232 * railHeight, tag = $edge5)
|> angledLine(angle = -45, endAbsoluteY = 0.087 * railHeight + originStart[1], tag = $edge6)
|> xLine(length = -0.183 * railHeight, tag = $edge7)
|> yLine(length = -0.087 * railHeight, tag = $edge8)
|> xLine(length = 0.06 * railHeight)
|> arc(angleStart = -90, angleEnd = 0, radius = 0.1 * railHeight)
// Sketch side 2 of profile
|> arc(angleStart = 270, angleEnd = 90, radius = 0.072 / 4 * railHeight)
|> yLine(length = 0.1 * railHeight)
|> yLine(length = 0.06 * railHeight, tag = $edge9)
|> xLine(length = -0.087 * railHeight, tag = $edge10)
|> yLine(length = -0.183 * railHeight, tag = $edge11) // edge11
|> angledLine(angle = 135, endAbsoluteX = ((1 - 0.356) / 2 + 0.356) * railHeight + originStart[0], tag = $edge12) // edge12
|> yLine(length = 0.232 * railHeight, tag = $edge13) // 13
|> angledLine(angle = 45, endAbsoluteX = (1 - 0.087) * railHeight + originStart[0], tag = $edge14) // 14
|> yLine(length = -0.183 * railHeight, tag = $edge15) // 15
|> xLine(length = 0.087 * railHeight, tag = $edge16)
|> yLine(length = 0.06 * railHeight)
// Sketch side 3 of profile
|> arc(angleStart = 0, angleEnd = 90, radius = 0.1 * railHeight)
|> arc(angleStart = 0, angleEnd = -180, radius = 0.072 / 4 * railHeight)
|> xLine(length = -0.1 * railHeight)
|> xLine(length = -0.06 * railHeight, tag = $edge17)
|> yLine(length = -0.087 * railHeight, tag = $edge18)
|> xLine(length = 0.183 * railHeight, tag = $edge19)
|> angledLine(angle = 45, endAbsoluteY = ((1 - 0.356) / 2 + 0.356) * railHeight + originStart[1], tag = $edge20)
|> xLine(length = -0.232 * railHeight, tag = $edge21)
|> angledLine(angle = 135, endAbsoluteY = (1 - 0.087) * railHeight + originStart[1], tag = $edge22)
|> xLine(length = 0.183 * railHeight, tag = $edge23)
|> yLine(length = 0.087 * railHeight, tag = $edge24)
|> xLine(length = -0.06 * railHeight)
|> arc(angleStart = 90, angleEnd = 180, radius = 0.1 * railHeight)
// Sketch side 4 of profile
|> arc(angleStart = 90, angleEnd = -90, radius = 0.072 / 4 * railHeight)
|> yLine(length = -0.1 * railHeight)
|> yLine(length = -0.06 * railHeight, tag = $edge25)
|> xLine(length = 0.087 * railHeight, tag = $edge26)
|> yLine(length = 0.183 * railHeight, tag = $edge27)
|> angledLine(angle = 135, endAbsoluteX = (1 - 0.356) / 2 * railHeight + originStart[0], tag = $edge28)
|> yLine(length = -0.232 * railHeight, tag = $edge29)
|> angledLine(angle = 45, endAbsoluteX = 0.087 * railHeight + originStart[0], tag = $edge30)
|> yLine(length = 0.183 * railHeight, tag = $edge31)
|> xLine(length = -0.087 * railHeight, tag = $edge32)
|> yLine(length = -0.06 * railHeight)
// Sketch center hole of profile
|> subtract2d(tool = circle(
center = [
.5 * railHeight + originStart[0],
.5 * railHeight + originStart[1]
radius = .205 * railHeight / 2,
|> extrude(length = railLength)
|> fillet(
radius = 0.06,
tags = [
getNextAdjacentEdge(edge3),
getNextAdjacentEdge(edge4),
getNextAdjacentEdge(edge5),
getNextAdjacentEdge(edge6),
getNextAdjacentEdge(edge11),
getNextAdjacentEdge(edge12),
getNextAdjacentEdge(edge13),
getNextAdjacentEdge(edge14),
getNextAdjacentEdge(edge19),
getNextAdjacentEdge(edge20),
getNextAdjacentEdge(edge21),
getNextAdjacentEdge(edge22),
getNextAdjacentEdge(edge27),
getNextAdjacentEdge(edge28),
getNextAdjacentEdge(edge29),
getNextAdjacentEdge(edge30)
|> fillet(
radius = 0.03,
tags = [
getNextAdjacentEdge(edge1),
getNextAdjacentEdge(edge2),
getNextAdjacentEdge(edge7),
getNextAdjacentEdge(edge8),
getNextAdjacentEdge(edge9),
getNextAdjacentEdge(edge10),
getNextAdjacentEdge(edge15),
getNextAdjacentEdge(edge16),
getNextAdjacentEdge(edge17),
getNextAdjacentEdge(edge18),
getNextAdjacentEdge(edge23),
getNextAdjacentEdge(edge24),
getNextAdjacentEdge(edge25),
getNextAdjacentEdge(edge26),
getNextAdjacentEdge(edge31),
getNextAdjacentEdge(edge32)
return sketch001
// Generate one adjustable rail of 80/20
rail8020(originStart = [0, 0], railHeight = 1.5, railLength = 48)
