Migrating to KCL 3.0
KCL 3.0 is a major improvement to the language that includes greatly improved fillets and the ability to define named views.
In addition to the new features, KCL 3.0 changes a few language rules and simplifies some standard library parameters. This page lists every change and shows how to update a program written in KCL 2.0. Each section has a "before" example that runs under KCL 2.0 and an "after" example that runs under KCL 3.0.
To use it, declare the version as the string 3.0 in the settings
attribute at the top of the file you execute:
The version declared by the file you execute governs the whole program, including every file it imports. A program cannot run partly under KCL 2.0 and partly under KCL 3.0, so migrate a project as a unit.
Migration steps
- Make sure you're starting from
@settings(kclVersion = 2.0)in the file you execute. If your file uses1.0or doesn't have a version specified, first add@settings(kclVersion = 2.0)and make sure it renders geometry as expected. - Fix all warnings. In particular, deprecated functionality may be removed in the next version, so you'll want to address these.
- Change to
@settings(kclVersion = 3.0)in the file you execute and in every file it imports. See All files must declare the same version. - Run the program and fix each error using the sections below. Most changes produce an error that points at the code to update.
- Check the resulting geometry. Some changes alter a model without an error:
filletandchamferrun in order with other operations and follow tangent chains by default, andsweepno longer moves the profile to the path by default.
Summary of changes
| Change | In KCL 3.0 | What to do |
use and enum are reserved | Using either as a variable name is an error | Rename the identifier and every reference to it |
template, lazy, and component are reserved after import | Using one as the first imported item is an error, even with an alias | Rename the export, move it later in the import list, or import the whole module |
return exits the function immediately | Statements after an executed return do not run | Move statements you need before the return |
if branches have their own scope | A variable declared in a branch is undefined after the if | Use the value of the if expression, or declare the variable before the if expression |
| The object is evaluated before the index | In a[b], a is evaluated before b | Usually nothing; check the order of operations if both sides create geometry |
fillet and chamfer run in order | An edge consumed by a cut cannot be looked up afterwards | Look up edges before the cut and store them in variables |
fillet and chamfer follow tangent chains | Edges tangent to the selected edges are also cut | Pass tangentChain = false to cut only the selected edges |
sweep no longer accepts relativeTo | The profile stays in place unless you say otherwise | Pass translateProfileToPath = true to move the profile to the path |
legacyMethod is removed | Passing it to fillet, chamfer, union, intersect, subtract, or split is an error | Remove the argument |
patternLinear2d requires a region | Passing a sketch block's sketch is an error | Pass a region(...) instead |
defaultAngleUnit is removed | The setting is an error | Write units on angles, like 90deg or 0.5rad |
| All files must declare the same version | An imported file declaring a different version is an error | Declare 3.0 in every file |
In KCL 2.0, use and enum were ordinary identifiers. In KCL 3.0, they
are reserved for future language features. Using either as a variable,
parameter, tag, or imported name is an error. Rename the identifier and
update every reference to it, including exports and imports.
The exception is a function named use: fn use() and use() still work
if ( immediately follows use, without whitespace. A function named
enum is an error.
KCL 2.0:
KCL 3.0:
KCL 3.0 reserves template, lazy, and component for future import
modifiers. In KCL 2.0, any of these names could be the first imported item.
In KCL 3.0, using one as the first item after import is an error, even if
you give it an alias with as.
Rename the export in the module it comes from and update its imports, or
import the whole module and access the name through it. If you import
several names, you can also move the reserved name later in the import
list, for example import other, component from "parts.kcl".
KCL 2.0:
KCL 3.0:
In KCL 2.0, return recorded the function's result, but execution continued
to the end of the function body. Statements after the return still ran. In
KCL 3.0, the first return that executes terminates the function. Statements
after it do not run. A return inside an if branch returns from the
enclosing function.
If a function has statements after a return that you rely on, move them
before the return. Otherwise, delete them.
KCL 2.0:
KCL 3.0:
Variables declared in if branches stay in the branch
In KCL 2.0, a variable declared inside an if, else if, or else branch
was visible after the if expression, and giving a branch variable the same
name as an outer variable was an error. In KCL 3.0, each branch body has its
own scope. A variable declared in a branch is visible from its declaration to
the branch's closing brace and never outside it, and it may shadow a variable
from an enclosing scope.
If code after an if uses a variable declared inside a branch, use the value
of the if expression instead, or declare the variable before the if.
KCL 2.0:
KCL 3.0:
In KCL 2.0, a member expression like a[b] evaluated the index b before the
object a. In KCL 3.0, it evaluates a first, in source order. This only
matters when both sides do something observable, such as calling functions
that create geometry or report errors. The geometry is the same, but the
operations run in a different order, which changes their order in the feature
tree and which error is reported first when both sides fail.
KCL 2.0:
KCL 3.0:
fillet and chamfer run in order with other operations
In KCL 2.0, fillet and chamfer were deferred until certain other modeling
commands or the end of the program. In KCL 3.0, they are sent to the engine
immediately, in order with the other operations.
This has two consequences:
- Cutting an edge replaces it with a new face. Looking up an edge that a
fillet or chamfer has already consumed, for example with
getOppositeEdgeorgetNextAdjacentEdge, is an error. Look up the edges you need before the cut and store them in variables. - Operations that follow a fillet or chamfer, such as a boolean or a sketch on one of its faces, now see the cut solid.
KCL 2.0:
KCL 3.0:
KCL 3.0 adds the tangentChain parameter to fillet and chamfer. When it
is true, the cut also applies to edges that are tangent to the selected
edges, so selecting one edge of a smooth loop, such as the top edge of a slot,
cuts the whole loop. It defaults to true. KCL 2.0 cut only the edges you
listed.
To keep the KCL 2.0 result, pass tangentChain = false.
KCL 2.0:
KCL 3.0:
sweep positions the profile with two flags
KCL 3.0 removes the relativeTo parameter of sweep. Use
translateProfileToPath and orientProfilePerpendicular instead:
translateProfileToPathmoves the profile to the start of the path before sweeping. It defaults to false.orientProfilePerpendicularturns the profile so that it is perpendicular to the path before sweeping. In KCL 3.0, it defaults to the value oftranslateProfileToPath, so a profile that is moved to the path is also turned to face along it unless you say otherwise.
The default behavior changed as well. In KCL 2.0, a sweep with no
positioning arguments turned the profile to face along the path. In KCL 3.0,
a sweep with neither flag leaves the profile where it is, in its current
orientation. When the profile is not already at the start of the path and
perpendicular to it, this gives a different shape. To reproduce a KCL 2.0
sweep, remove relativeTo, pass translateProfileToPath = true, and check
the result.
KCL 2.0:
KCL 3.0:
The legacyMethod parameter of fillet, chamfer, union, intersect,
subtract, and split opted back into an older engine algorithm. It was
deprecated in KCL 2.0 and is removed in KCL 3.0. Passing it is an error.
Remove the argument.
KCL 2.0:
KCL 3.0:
In KCL 2.0, passing the sketch produced by a sketch block directly to
patternLinear2d was deprecated with a warning. In KCL 3.0, it is an error.
Select the profile to pattern with region and pass the region instead.
KCL 2.0:
KCL 3.0:
The defaultAngleUnit setting was deprecated in KCL 2.0 and is removed in
KCL 3.0. Declaring it is an error. Remove it from the settings attribute and
write the unit on every angle, like 90deg or 1.57rad.
KCL 2.0:
KCL 3.0:
In KCL 2.0, each file ran under the version it declared, so a program could
mix files declaring 1.0 and 2.0. In KCL 3.0, the version declared by the
file you execute governs the whole program. Every imported file that declares
a kclVersion must declare the same version, and an imported file that
declares no version uses the executed file's version. Declaring the version
in every file is recommended, so that opening an imported file on its own
does not run it under the default of 1.0.
The check works in both directions. A file that declares 3.0 can only be
imported by a file that declares 3.0, so migrating only some files of a
project is an error either way.
KCL 2.0:
KCL 3.0:
If you update main.kcl but not dimensions.kcl, executing main.kcl
reports an error like this:
Recommended: replace deprecated sketch functions with sketch blocks
This step is not required, but strongly recommended. The pipeline-style sketch
functions from KCL 1.0 have been deprecated since KCL 2.0. The functions such as
startSketchOn, startProfile, and close, and the segment functions used in
those pipelines, such as line, xLine, angledLine, arc, tangentialArc,
circle, rectangle, and polygon, still work in KCL 3.0 and report a
deprecation warning. The functions of the same name used inside a sketch block,
such as line and arc, are not deprecated. While you are updating a file,
consider rewriting these profiles as sketch blocks
and selecting the profile to extrude with
region so that you can take
advantage of geometric sketch constraints.
KCL 1.0:
KCL 3.0:
