Importing geometry from other CAD systems
import can also be used to import files from other CAD systems. The format of the statement is the
same as for KCL files. You can only import the whole file, not items from it. E.g.,
For formats lacking unit data (such as STL, OBJ, or PLY files), the default unit of measurement is millimeters. Alternatively you may specify the unit by using an attribute. Likewise, you can also specify a coordinate system. E.g.,
When importing a GLTF file, the bin file will be imported as well.
Import paths are relative to the current project directory. Imports currently only work when using the native Design Studio, not in the browser.
Supported values
File formats: fbx, gltf/glb, obj+, ply+, sldprt, step/stp, stl+. (Those marked with a
'+' support customising the length unit and coordinate system).
Length units: mm (the default), cm, m, inch, ft, yd.
Coordinate systems:
zoo(the default), forward: -Y, up: +Z, handedness: rightopengl, forward: +Z, up: +Y, handedness: rightvulkan, forward: +Z, up: -Y, handedness: left
Performance deep‑dive for foreign‑file imports
Parallelized foreign‑file imports now let you overlap file reads, initialization, and rendering. To maximize throughput, you need to understand the three distinct stages—reading, initializing (background render start), and invocation (blocking) —and structure your code to defer blocking operations until the end.
Foreign import execution stages
Import (Read / Initialization) Stage
- Reads the file from disk and makes its API available.
- Starts engine rendering but does not block your script.
- This kick‑starts the render pipeline while you keep executing other code.
Invocation (Blocking) Stage
- Any method call (e.g.,
translate,scale,rotate) waits for the background render to finish before applying transformations.
Best practices
1. Defer blocking calls
2. Split heavy work into separate modules
Place computationally expensive or IO‑heavy work into its own module so it can render in parallel while main.kcl continues.
Future improvements
Upcoming releases will auto‑analyse dependencies and only block when truly necessary. Until then, explicit deferral will give you the best performance.
