Sketch on Face
When you sketch on a plane and extrude, a new solid is created.
However, when you sketch on the face of an existing solid, extruding extends the existing solid.
The result is that there's only one solid. You can think about this as being equivalent to making a new, separate solid and unioning the two in a single operation.
On the other hand, if you don't want to change the initial solid and create a new solid instead, there are a couple ways to do this.
The first way is instead of starting the sketch on the face of the solid, start the sketch on the same plane. Since it's not directly on the first solid's face, extrusions do not modify the solid. They create new solids instead.
The second way to create a separate solid is by using the method parameter of extrude(). You can start the sketch on the face, but when extruding, specify that the method should create a new solid using method = NEW.
Once you have a separate solid, you can translate or rotate it separately or use boolean operations like union, subtract, and intersect.
If you intend to create a single solid, you should prefer to sketch-on-face since it's more succinct, efficient, and robust. But sometimes you need the flexibility of creating a separate solid.
