Ben's Build Logs: Single-Engine Aircraft
Ben Friedel
Ben Friedel
Hey, Ben the intern here! 👋
I’m an aeronautical engineering student working with Zoo to explore what practical engineering looks like in Zoo Design Studio.
In this series, I’m designing a small single-engine aircraft piece by piece and sharing the process along the way.
Hope you enjoy following along! ✈️
~ Ben (@benfrdl)
Jump to latest update ↓ - Latest: Build Log #19 · Nov 9, 2026
#1 - Aug 12, 2026
While creating the aircraft tires, I built the outer tire cross-section manually to define the geometry.
Instead of recreating essentially the same shape again for the inner profile, I handed that part to Zookeeper. One prompt later, it reproduced the profile with a consistent offset.
#2 - Aug 17, 2026
For the wheel rims, I needed some info on how the bolt assembly is typically constructed on aircraft wheels.
I asked Zookeeper for some technical context and it gave me a breakdown and technical drawings to support my modelling.
#3 - Aug 21, 2026
I was modeling the fork and oleo strut of the nose landing gear when I wondered if Zookeeper could take over from there.
It completed the assembly and even suggested the next steps.
#4 - Aug 25, 2026
To model the aircraft wing, I first needed to define the rib and its spar geometry.
I sketched out the rough profiles I wanted by hand and gave them to Zookeeper to size them properly.
#5 - Sep 3, 2026
A wing obviously has more than just one rib, so I let Zookeeper duplicate the rib along the entire wingspan.
Then I had him extend the spars and stringers through all the ribs to complete the internal wing structure.
#6 - Sep 9, 2026
Before finishing the wings, I wanted to start on the aircraft’s piston engine, beginning with the crankshaft.
I noticed I had gotten the propeller mounting flange slightly wrong, so I gave Zookeeper reference images of a real aircraft crankshaft.
Zookeeper corrected the geometry and laid the groundwork for the rest of the crankshaft.
#7 - Sep 22, 2026
After modeling the crankshaft and pistons, I asked Zookeeper to bring everything together.
Instead of positioning every part myself, he took over and assembled the almost complete engine internals.
#8 - Sep 25, 2026
For the valve mechanism, I needed to add compression springs, but wasn’t sure about the best way to model them in Zoo Design Studio.
So I asked Zookeeper which approach he would recommend. He suggested using a helix, which turned out to be exactly what I needed for the spring geometry.
#9 - Sep 28, 2026
To finish up the wing structure, I first refined the stringers to make them more representative of a real aircraft.
On top of that, I modelled two different spar angle designs and gave Zookeeper the placement logic for each of them.
He then positioned and duplicated all 45 angles across the wing structure.
#10 - Oct 1, 2026
Of course, the wing still needed a proper wingtip, so I gave Zookeeper the existing wing geometry and some basic design requirements while leaving the actual shape mostly up to him.
The first result looked promising, but wasn’t quite there yet. With a few more prompts, I refined the geometry and ended up with a final version that felt much more convincing.
#11 - Oct 5, 2026
In the Zoo Aquarium, I came across a different approach to generating a wing’s NACA profile, so I asked Zookeeper to compare it with the method I was already using.
Turns out my approach was better suited for this model, so I kept it and completed the wing assembly with the final additions of the ailerons and outer skin.
#12 - Oct 8, 2026
An important part of the crankshaft and camshaft setup is the timing connection that keeps both shafts synchronized.
In a four-stroke engine the camshaft rotates at half the crankshaft speed, so I had Zookeeper create a 2:1 gear setup between them.
#13 - Oct 13, 2026
While reviewing the engine assembly, I realized there was a deeper logic issue in the way I had arranged the layout.
After working through the problem with Zookeeper and exploring a few possible fixes, I reworked the affected geometry to better match the flat-four configuration typical for this kind of aircraft engine.
The result is a more mechanically plausible setup that I’m much happier to continue with.
#14 - Oct 17, 2026
With the rest of the engine components in place, I asked Zookeeper to create a functional linkage between the camshaft lobes and the valves.
The first result already had the basic mechanism in place, but some of the geometry still needed refinement.
After a few adjustments to make the setup cleaner and more realistic, the engine internals were finally complete.
#15 - Oct 21, 2026
Moving on to the propeller, I asked Zookeeper to design a mounting plate that fits the existing crankshaft flange.
I had him start with a sketch so I could review and validate the design before letting him turn it into the final 3D part.
#16 - Oct 23, 2026
With KCL 3.0 released, I asked Zookeeper to migrate the entire project, review the existing code and make sure everything still worked as intended.
With that done, I finished the propeller spacer, making use of the improved fillet capabilities in KCL 3.0 to smooth out the transitions around the mounting bolts and structural ribs.
#17 - Oct 31, 2026
Before modeling the propeller itself, I asked Zookeeper to evaluate what kind of fixed-pitch propeller would make sense for this type of aircraft and to work out suitable dimensions and blade profiles.
He then used that information to create a series of sketches, visualizing the blade shape, twist and overall proportions.
#18 - Nov 4, 2026
Next up was figuring out how to mount the propeller to the aircraft.
I asked Zookeeper to integrate the propeller hub with the existing spacer and design the forward and aft bulkheads as part of the mounting assembly.
#19 - Nov 9, 2026
For the propeller spinner, I drew a sketch by hand to communicate the shape I wanted.
I gave the sketch to Zookeeper, which turned it into a 3D model and fitted it to the existing mounting structure.
Follow the build
More build logs are on the way, with new posts two to three times a week. We’ll update this post with each new entry as it’s published, keeping the full text and images together here so you can follow the project from the beginning.
Read the latest build log (#19) on X or LinkedIn. Check back here as the build progresses.
