3-Blade Foldable Drone Rotor
MakeathonAerospace
Makeathon Winner
🥉 3rd Place
The level of thoroughness here was seriously impressive. The electric motor assembly was detailed, functional, and thoughtfully constructed. It felt like a real engineering project with a ton of care put into making the assembly actually work.
Submitted by: benfriedel
A compact 3-blade foldable drone rotor built around a passive hinge mechanism. The model includes aerodynamic folding blades, a layered sandwich hub with washers and hinge pins, a central shaft with locking nut, a prop adapter and a simplified outrunner motor with ventilation details and cable routing.
