Submitted by: reyan36
Geometric wall shelf system designed as a sculptural storage piece with three distinct forms. Dimensions ✱ Shelf width: 400 mm ✱ Shelf depth: 200 mm ✱ Back thickness: 45–90 mm (varies per shelf) ✱ Front edge: 6–12 mm tapered ✱ Mounting holes: Ø12 mm × 40 mm deep ✱ Hole spacing: 200 mm ✱ Total height span: ~340 mm Features ✱ 3 unique shelf bodies: wedge ramp, trapezoid platform, and arrowhead form. ✱ Flat top surfaces usable for display objects. ✱ Clean rear mounting tunnels for hidden rod support. ✱ Fully parametric.
Loading votes...
