Monitor Arm Clip
Submitted by: reyan36
Cable management spine designed to clip onto any monitor arm and route cables cleanly along its length. Dimensions ✱ Segment length: 30 mm, Joint gap: 6 mm, Segment pitch: 36 mm ✱ Outer segment size: 44 × 26 mm ✱ Internal cable channel: 34 × 16 mm ✱ Sample spine length: 210 mm (6 segments) ✱ Monitor arm clip: 54 × 42 × 40 mm Features ✱ 6 articulating vertebra segments with ±20–22° yaw per joint. ✱ Fits up to 4 large monitor cables or 6 smaller 3 to 4 mm cables. ✱ C-clip cradle snaps onto the monitor arm tube with optional 4.8 mm lock-pin hole. ✱ Modular each extra segment adds 36 mm to the spine length.
