Pyramid Self Watering Planter
Submitted by: reyan36
Pyramid shaped Self Watering Planter designed as a sculptural piece for indoor/outdoor plants. Built as a Z shaped silhouette when viewed from the front. Features ✱ Hollow planter bowl ✱ Built-in triangular self watering reservoir ✱ Drainage holes at the lower tip Build ✱ Part 1: Inverted square pyramid planter ✱ Part 2: Diagonal flat connector panel ✱ Part 3: Solid square pyramid base
Loading votes...
