Reduce and geometry
WARNING: This chapter covers the old syntax for our previous sketch library (that didn't support constraint solvers). If you're new to KCL, you should probably skip this chapter and read the new chapter on sketch blocks. If you've already got old KCL code that used the old syntax for sketching, don't worry, you can keep using the old syntax, and this chapter will explain it. But new users shouldn't worry about this, unless they're working with old code.
- Sketching a square with reduce
- Sketching a parametric polygon with reduce
- Repeating geometry with reduce
The reduce function lets us iterate over an array, consuming its contents and reducing them down to one single item. Reduce is a very powerful, flexible tool. It can be complex too, but that complexity lets us do some very interesting things.
For example: how would you write a KCL function that produces an n-sided polygon? This is an ambitious project, so let's start with something simpler, and build back up to an n-sided polygon.
Can we use reduce to make a square function, first? Once we've done that, we can make a parametric sketchPolygon function that works like square when the number of sides is 4, but can just as easily produce hexagons, octagons, triangles, etc.
fn square(sideLength) {
emptySketch = startSketchOn(XY)
|> startProfile(at = [0, 0])
angle = 90
fn addOneSide(@i, accum) {
return angledLine(accum, angle = i * angle, length = sideLength)
return reduce([1..4], initial = emptySketch, f = addOneSide)
square(sideLength = 10) |> extrude(length = 1)
What's going on here? Let's break it down. We declare fn square which takes one argument, the sideLength. We create an initial empty sketch (at [0, 0] on the XY plane), and declare that the angle is 90.
Next, we declare a fn addOneSide. It takes in two arguments: i, which represents the index of which side we're currently adding, and accum, which is the sketch we're adding it to. This function adds one angled line to the sketch. The line's side is whatever side length was given, and its angle is 90 times i. So, the first line will have an angle of 90, the second 180, the third 270, and the last 360.
Then we call reduce, passing in the array [1, 2, 3, 4], setting the initial accumulator value to the empty sketch we started above, and calling addOneSide every time the reduce handles an array item. When reduce runs, it:
- Starts
accumas the empty sketch - Handles the first item,
i = 1, callsaddOneSide, which takes the previous accumulated sketch (currently empty) and adds an angled line at 90 degrees. This becomes the next accumulated sketch. - Handles the second item,
i = 2, callsaddOneSide, which takes the previous accumulated sketch (with a single line) and adds an angled line at 180 degrees. This becomes the next accumulated sketch. - For
i = 3, it takes the accumulated sketch with two lines, and adds a third line, similar to the previous step. - For
i = 4, it takes the accumulated sketch with three lines, and adds a fourth line, similar to the previous step.
Thus it builds up a square.
OK! We've seen how to use reduce to add lines to an empty sketch. We're ready to make our polygon function. Although, KCL already has a polygon function in the standard library. So, to avoid clashing with the existing name, we'll call ours sketchPolygon.
We can start with our square function and generalize it. First, we'll add an argument for the number of lines.
fn sketchPolygon(@numLines, sideLength) {
We can use the same initial empty sketch. We'll have to change angle, because it won't be 90 anymore. The angle now depends on how many edges the shape has:
angle = 360 / numLines
And lastly, our reduce call will need to take an array of numbers from 1 to numLines, not 1 to 4. So we'll use [1..numLines] as the first argument to reduce.
Let's put all that together:
initial = startSketchOn(XY)
finished = reduce([1..numLines], initial = initial, f = addOneSide)
return finished |> close()
sketchPolygon(7, sideLength = 10) |> extrude(length = 1)
pattern2D and pattern3D, so we hope to add a pattern1D eventually, so that these complicated reduces won't be necessary. Until then, reduce can be a good way to implement tricky functions like sketchPolygon.
Let's look at another way to use reduce. Say you're modeling a comb, with a parametric number of teeth. We can use reduce to solve this again:
fn comb(teeth, sideLength) {
toothAngle = 80
handleHeight = 4
// Sketches a single comb tooth
fn addTooth(@i, accum) {
// Line going up
return angledLine(accum, angle = toothAngle, length = sideLength)
// Line going down
|> angledLine(angle = -toothAngle, length = sideLength)
allTeeth = reduce([1..teeth], initial = initial, f = addTooth)
finalComb = allTeeth
// Add the handle: a line down, across, and back up to the start.
|> yLine(length = -handleHeight)
|> xLine(endAbsolute = 0)
|> yLine(endAbsolute = 0)
return finalComb
comb(teeth = 10, sideLength = 10) |> extrude(length = 1)
We write a function addTooth which adds a tooth (going up, then back down) to a sketch. Using reduce, we can call that function teeth times. Each time, the new tooth gets appended to the end of the sketch path. Once we've drawn all the teeth, we draw a simple handle leading back to the start.
reduce is a powerful way to make parametric designs, repeating geometric features as many times as you need. You can design parametric polygons with a variable number of sides, or repeat geometry linearly (like we did for our comb).
