Coilover Assembly
Mechanical ComponentsAutomotive & Transportation
Submitted by: ZooTeam
Consist of a lower and upper body combination with eye-end mounts at the top and bottom. 200 mm-long helical spring (44 mm OD, and wire diameter of 6 mm) captured between upper and lower seats; Internal piston rod running through the spring. Integrated bump-stop beneath the upper seat to limit compression stroke. The assembly provides adjustable ride height and damping when installed between chassis and wheel hub.
Coilover Assembly
